1 - 4 of 4 Posts
Well, I'm about to replace my headgasket on the B20A (Accord) and I came on a small problem
Honda recommends 49 lb-ft but the paper that came with the headgasket recommends 51 lb-ft with a retorque sequence after one heat cycle.
I guess that the 2 lb-ft doesn't really matter but do we really need to retorque the bolts after 1 heat cycle?
I had an oil leak in front of the engine so this is the reason I replaced the headgasket. Maybe I should have just retorqued it but decided to replace it since it's a pain to reach the head bolts. (engine did 3500 miles since rebuild)
Maybe the gasket makers are assuming you wont use some sort of torquing lubricant? Hmmm
What make of gasket is it.
None of the ones I've used need re-torquing and tbh they shouldn't.
Should be used dry and torqued as per the manual.
Only it being a spurious gasket would alter this.
1 - 4 of 4 Posts
