hey guys im new to the fourth gen stuff I have an 86 lude I circle track race with that I love just need to move into something fuel injected and I came across a 92 prelude with the H23a1 in it and was curious if I could swap the head for an H22a1 vtec head and get better compression ratio and get my variable timing
I noticed that the H23 has a lower compression ratio is that due to the head? the pistons?
now besides shaving the H22 head I was curious what would be the best way to get the compression ratio back up with stock components on the H23 bottom end? could I use the H22 pistons with the H23 connecting rods and crank? I dont really want to spend a ton of money on a fancy set of pistons either
whats the most RPMS that the H23 bottom end stock can take? because I know the H22 can REV to 9000 all day long
now if I can swap heads what ecu would I have to run?
and how many different options for transmissions would I have if I ran the H23 bottom end? manual of course!!! does the H22 trans work? is it a different gear ratio?
and are any of the stock components forged? or all cast?
any and all help and advice is appreciated!!!!!!
