1 - 14 of 14 Posts
so when i hit 5.5k rpms my car blocks off as if i were redlining
i thought i would need a bigger fuel pump but i found out that its the same or something
any help?
check engine light, cloged injectors , cloged fuel pump or rail or fuel filter, any noise ? help me out so we can help u out post a vid thanks
yeah its hard to tell you what it could be from that info... theres a lot it could be... do you have aftermarket stuff on it... is it stock... all kinda of stuff we need to know for that
any help?
Need more input, is your check engine light on. We don't even know what engine you have in there. This diagnosis stuff is like algebra, we do need part of the equation to find the missing variable or else you are just going to get too many answers.
it says h22a vtec bogging down in his title... so id think he has an h22a but not totally sure... maybe i just cant read lol jp yall but that is really in his title
lol, I see that now.
man i had some guy the other day come in a 4th gen lude thinking they all had h22's and he had a non vtec f22 engine
lol sorry i wrote that late at night
no check engine light
its stock pretty much just after market exhaust, header, intake
i still have the old tach from my h23 and it seems to block off at the old red line but thats probably just a coincidence..
not really any noise except loud noise from the exhaust
thanks for the help i could use any input
i might just have a mechanic look at it
it sounds like my vtec kicks in but the engine blocks off so i dont really have time to listen
Is it a recent swap? I dont know for sure what the redline is on the H23 or F22 or whatever your car came with, but maybe it has the old engines ECU still. Are you sure you are hitting VTEC? Cause Vtec kicks in at about where you are "redlining" or cutting off.
check your spark plugs, plug wires, injectors, all your fuel crap and after that make sure you have the right ecu to run the h22 and not an h23.. the h23 redlines at 6500 rpm but your sayin to bogs about 5500 which is where stock vtec kicks in but then again... it shouldnt kick if you dont have the right ecu i dont think... but if the car is good up to 5500 rpm then drive it normal till you find the problem to get her fixed up right
i have the h22 ecu in that the motor came with
i think ill change the oil on friday and get new plugs and wires and see if that does anything
the injectors are the ones that the motor came with (with extensive cleaning -___-;)
and i tried revving as high as i could and it blocks off at 6k rpms
lol the other numbers were just me glancing but i was paying attention this time
thanks for all the help :)
appreciate it greatly
1 - 14 of 14 Posts
