1 - 2 of 2 Posts
In my H22 swap I have the oil pump with a plug coming out the bottom for the crank position sensor. I read online that this must be swapped out or wired to the distributor to make work since the the crank position sensor is in the distributor on OBD1. Wouldn't you think I would be fine If the distributor plugs into the harness or do I have to switch out oil pumps? Anyone run into this issue?
Memento Mori
You just need an OBD1 distributor. You can leave or remove the crank sensor since it is not used on the OBD1 harness.
1 - 2 of 2 Posts
