1 - 7 of 7 Posts
I've got a 94 prelude s dohc non vtec and its got a pretty nasty miss. I've changed the plugs, plug wires, distributer cap, rotor and o2 sensor and it hasn't gotten any better. I'm just curious as to what else it may be. Any help is appreciated.
Check for vacuum leaks using a can of carb cleaner, and I'd also check compression in every cylinder.
I do I use carb cleaner to check for vacuum leaks?
Also I checked the compression and they were
1:180
2:180
3:184
4:176
Sounds like compression isn't the issue. Have you checked with a spark tester in each well to ensure spark is getting where it needs to go?
And this YT vid describes how to check vacuum leaks using carb cleaner:
https://www.youtube.com/watch?v=9CPqbaSgcok
Discussion Starter #5
1:180
2:180
3:184
4:176
I'll check it out and no I haven't checked the spark tester I'll have to try that too. Thanks!
You're welcome, best of luck with that.
1 - 7 of 7 Posts
