1 - 17 of 17 Posts
is it entirely necessary for me to get one of these? im only running 7 psi. i was just going to use the 3 check valve thing that tricks the map sensor from reading boost.
and what exactly is the significance of a 3 bar MAP sensor on a turbo application neway?
uhh... the stock map sensor is a 1.75 bar map sensor. that will read fine up to 10psi or so before it saturates.
and you shouldn't be using a check valve on the map sensor line... use CROME or Hondata or MS... you only need a check valve if you are sticking with your stock ECU and going the AFC, FMU route. that route = bad idea.
oooooooo ok i didnt even know that. cool thanks man i thought that if the MAP saw any boost what so ever then it would throw a code.
i learn shit everyday on this site.
by the way, i know youve been working on a turbo set up for a while are you boosted yet?
the stock sensor WILL throw a code.. if it sees boost on a STOCK ECU. Running a Standalone with Boost options added.. no codes will be thrown, and you can safely boost/read MAX 10 lbs on teh Stock MAP sensor.
only run the Check Valves if you plan on Sticking with the Stock ECU.
well on your sig it says your gonna get a different computer and put crome on it so your not going to need the check valve. If your only going to run 7 psi you could use the stock sensor but just to be on the safe side and incase you ever wanna turn it up a little go ahead and get the 3 bar. If your spending all this money on your turbo system you might as well get it wont do any harm and could help you down the road.
No... dont just get e 3bar to have one... get one that reads within the limit you are wanting to boost - You will have better resolution on it when you begin to tune.
he said he's looking at a gm one which one that i've seen alot of people run succesfully, hence why i said to go ahead and get it.
i know why you said it..
but....
lets say you dont plan on boosting more than 15 lbs EVER... why would you get a 3 bar? you would be better off getting a 2 bar to which will give you far greater resolution in the boost columns when you are ready to tune...
dont just get a 3bar to get one... get something that will give you greater clarity on your setup and your tune.
G
for your setup and an ems you wont need a new map sensor. stay with the one you have unless you go above 11psi.
so next summer when i do my internals and bump her up to say 10-12 psi i should be looking into getting the gm 3 bar map sensor?
how much boost do you plan on running MAX throught the lifetime of the setup?
i have a GM 3bar for sale...
i would get a 2.5 bar
you;d be good up to 21 lbs with it..
and it will give you good resolution for tuning at 15 lbs.
I'm running a GM 2 bar of an 81 Turbo T/A....works fine. I beleive the 2.5 Bar sensor is on the Chrysler Turbo's...someone correct me if I'm wrong. Chrysler Maps are a two piece design.., ugly and take up more space.
1 - 17 of 17 Posts
