1 - 3 of 3 Posts
My 92 Prelude Si hadn't been driven in a year or so and the battery was shot. When I got the car back up and running again, the gas and temp gauges aren't coming on on the dash.
Fuses seem ok... Any ideas?
Thanks.
You can check the connections at the cluster itself, though it's most likely an internal fault which is reasonably common at the age of 4th gens now.
Mine did the same last weekend, swapping out the cluster fixed it.
Thanks.
It's a common problem, I did replace mine.
1 - 3 of 3 Posts
