1 - 16 of 16 Posts
masterkilla i asked u 2 times i have the si swaybar with upgraded urethane bushings and yes the si is bigger do u want to get this from me or ill trade u the sway bar for that nice c pillar bar
its smaller than 16. if i had a caliper id check.
masterkilla should be able to measure it soon as he gets he bought my old one
sway bar bushings
When I replaced the bushings on my old Accord I used a micrometer to measure the bar (it's the same diameter everywhere, except the bends) and converted from inches to mm. After I got the old bar off I discovered the bushings had the size imprinted in the rubber on the side. You might get lucky crawling under with a flashlight and be able to see the size.
1 - 16 of 16 Posts
