1 - 10 of 10 Posts
have anyones flashers just stoped working...
i know the fuse is also on my oil light and door beeper but, my hazard lights and turn signals dont work...
im gonna search but if this has happened to anyone help would be apreciated..., maybe evem a link to the online manual...
1990 prelude 2.1 SI
im having a semi-similar problem when ever i take the dash off and all the controls...hook them up direct my flashers work...but when in the dash and installed does not function properly anymore..
im sure you have checked your bulbs
i did... but they all seemed fine....
but if one doesnt work (burnt out) would they all not work...?
if one bulb goes out, the flashers will still work, they'll just flash twice as fast to let you know you have a bulb out. its part of the design of the flasher.
if they all dont work, either the flasher is shot (yess, its called a flasher in most cases, its the relay that actually makes them blink), the relay may be shot, or most commonly; the switch may be shot. the switch is what the actual signal lever is attached to...
all 4 (well6) of my flashers work , but they blink like twice a second :grin:
1 - 10 of 10 Posts
