1 - 14 of 14 Posts
To start off The f23a is a obd2 engine so you will have to dumb it down to obd1. Thats why i have some f22b1 and h22 parts cause they are OBD1 from 90-95
Parts list
f23a 93-01 honda accord ex
MPT3-A1 5speed manual transmission out of a 90-93 Honda accord
H22 Motor mounts - 1funryd/
explicitspeedperformance
Traction bar - 1funryd/
H22 Conversion harness -1funryde/wireworx. new version is plug and play
2wire knock sensor (can wire in a 1 wire knock sensor) - ebay
H22 idle air control valve -ebay
H22 idle air control valve adapter - roske
racing
4th gen prelude injector resister box - eBay
Obd1 f22b1/h22a distributor (1 plug, not 2 plug distributor or you will have to use wireworx distributor jumper or make your own)
Obd1 ecu for f22b1/f23 or a p28,p72,p75,p06 - ebay
Blox egr block off plate - ebay
Obd1 fuel injectors f20, f22, h22 - ebay
Axles - 93-98 honda accord - ebay
Shift linkage - 93-98 honda accord - ebay
Shifter - 93-98 honda accord - ebay
Getting engine in and mounted
All mounts and traction bar will be installed after you get engine and transmission in the engine bay below the engine mounts mounting spots. The more room in the engine bay the better it is a very tight squeeze. you will need to lower the engine and transmission in diagonally for it to fit then once you got it pass where the mounts would attach to the body you can . turn it to the correct way and attach your mounts to their correct spots no needing to make new holes for mounts. The stock location will work but leave the mounts that are connected to the engine loose and the mounts on the chassie tight. as you raise the engine with the mounts attached to it and to the chassie you will need a pry bar to pry and force the mounts to line up right leaving the mounts on the block and transmission loose helps with this starting with the driver side mount then getting rear mount done and finally passenger side and traction bar installed traction bar will replace the front subframe. If using a jdm fuel rail you will have to find a way to attach or extend the fuel line to reach
Vehicle Automotive fuel system Motor vehicle Automotive air manifold Automotive design
Vehicle Car Motor vehicle Automotive design Hood
Vehicle Car Wheel Hood Motor vehicle
Runs from ecu to and through engine bay. Mostly plug and play. Each plug/connector is labled. have to change and extend oil pressure sensor from a eyelet to a female push connector, extend knock sensor plug and swap out the idle air control valve using h22 idle air control valve and adapter plate everything else should be plug and play. will no longer need that ugly black box on the passenger side fire wall
Axles
I used a 93-98 honda accord. Fits perfect to trans/motor into stock hubs. Will have to use f22b1/f23a half shaft for driver side
Shifter and shift linkage/cable
I used a 93-98 honda accord set up. Will have to cut out a spot for the shifter to sit flush since the shifter sits down into the middle console instead of on top like stock preludes shifters do. Shift linkage needs no mods or fabrication goes just like the stock shift linkage./cable
ECU
I used a obd1 p06 ecu and it plugs right up to the conversion harness. Strictly plug and play with wireworx new version of the harness
So the F23a oil pressure and Knock sensor are longer with the harness?
Not sure what you mean by with the harness. I had to add about 3-6 inches to the conversion harness inorder to reach the knock sensor and oil pressure. The harness by itself wouldn't reach the knock sensor or oil pressure
I mean, the H22 swap is different from the F series swap in that there are wires that need to be extended vs they just plug and play.
When you said on the
Would u still have to cut out a spot if you were to use a automatic transmission?
That I do not know the automatic shifter might be different. I only dealt with manuals
You always have to cut that area to make clearances, our chassis is no the same as the newer Accords or Preludes.
1 - 14 of 14 Posts
