1 - 7 of 7 Posts
Before you buy the harness make sure it will work, there are some changes from year to year so.
http://filedump.org/files/IogL1365102324.html
i've uploaded an xps of the engine harness connector and ground locations. it should help. only advice i can give is be careful unplugging the knock sensor which is located directly below the center of the intake manifold. they have a tendancy to break. oh, and take lots of pictures of your orig harness installed in the car before you start, it'll give you something to refer back to. if you get stuck just post pictures here and im sure we can help you.
1 - 7 of 7 Posts
