Hi fellow 3rd gen enthusiasts,
after rebuilding the engine and starting the car, I realised that I couldn't turn it off by turning (or removing) the key.
As soon as I connect the battery, the dashboard lights up, main relay clicks and the fuelpump starts humming.
At first I thought it had something to do with the ignition switch, but even when I disassembled it and disconnected the plug from the fuse box, the problem persists.
I tracked down the problem to have something to do with the ACG (S) fuse.
Upon disconnecting the main relay the pump stops but the dashboard is still on.
Radio turns on normally on the ACC position and the starter works fine too.
I hope someone here is able to tell me why this happens and which cable or component is broken.
