Hi, have a 92 Prelude si 2.3 NON vTec. Only thing aftermarket is the intake. Even has FACTORY EXHAUST. A survivor. Idles fine, past 1000 rpms, missing & falls on it's face. Replace the fuel pump and filter, fuel pressure is good. Have a place the entire ignition system from the camshaft out. Replace timing belt, timing is correct. Compression test is good as well as leak down. Only DTC is the knock sensor, which is crazy as I've replaced it 3x nd it still ahrow the code. Found a burnt component in the ECU, replaced that. If cold, seems to idel fine but as it warms up, you start to hear that miss creeping in.. I'm STUMPED! Help! And thanks!
