Hello! I bought honda prelude 1994 with swapped H23A bluetop engine, and i have driven it just fine for about 500km, until I finally changed the oils, put a bit too much oil and started driving home. About 10km later the engine started stuttering and died. I towed it home and started investigating. The engine does crank just fine, and spark plugs seem to be in ok condition, and smell like fuel but the engine wont start. Any clues? Tomorrow I will check the distributor and ignition cables, since I believe this could be ignition issue. Share some knoledge and experiences if you have had similar issues. Thank you in advance!
Discussion Starter #2
I also checked that the engine has not leaked anything, or didin't spit any smoke due to the excess oil, so I dont suspect any internal damage on the engine itself, but probably ignition has worn out (the car had been sitting 7 years before I bought it).
If it cranks (assuming compression), and has fuel, then it only needs a spark. So, is there a spark?
Discussion Starter #4
No it does not, I replaced the distributor cover, wheel and spark plugs, no luck. Currently replacing the ignition coil to see if that helps.
