master bater
I have an air horn on my lude and my battery never has enough juice to run it. It physically moves the pump but not enough to work the horns. I have it wired to my fuse box. What can I do to get it enough power?
Thanks,
Wayne
it sounds like you got a old school ogoogh horn back in the day they had to add a booster box so they would sound good all it did was give it more power orelse it would sound sick i cant think what it is called and i got to go but i sure someone will beable to tell you
master bater
you can hook up a relay and pull the power from the batt and not the fuse box
also if you hook it up to the batt .will it work ? you might have a air leak ?
I can try hooking it directly to the battery and see what happens. The horn does work if the battery is fully charged without any accessories running, and I have to be driving down the road. Its just not getting enough power.
thats what i was going to say, run the power directly from the battery with a high current relay, using the regular horn button or a seperately mounted pushbutton switch to use as the trigger for the relay.
