1 - 3 of 3 Posts
My fourth gen current have hard time starting. Also the subs that i have will not work, they will work for about 10 sec or so and start fading and will make buzzing noise. I have checked the wiring and fuse and they are good. So i have narrowed down to alternator, spark plug, and battery. What do you think the problem is?
Get a diagnostic done at AutoZone. They will print out the results of your alternator output. Also check the wiring between the alternator and the battery.
Can you describe how that car is starting up? Does crank a couple of times then finally fire up or what?
ya it will crank for a few then start up just fine, its worse when its really cold outside.
1 - 3 of 3 Posts
