1 - 12 of 12 Posts
Hey guys so i have a 01 base model. The previous owner did a swap from the h22a to a f20b motor. Said something about needing new harness and ecu to get vtec to work? I have been out of the loop for a while. Csnt someone point me in the right direction please and thank you..
Could have just ment he did not get the right ecu and harness it comes with? Try to track down your :search: compatible ecu, and harness. Then you can check your vtec solenoid as-well.
Discussion Starter #3
He said vtec would work cause it needs correct ecu and harness. Said something about needing ob1 ecu? Not really sure
Does the Vtec Solenoid have two connectors on it or one? Like connectors to plug into? Sounds like he left the Jdm Vtec solenoid on which only has 1 sensor, the stock Vtec solenoid for a usdm 5th gen has 2 sensors on it. Check that and that should say a lot about what’s going on.
It is possible for a Jdm F20b/ H22/23a to work on a Usdm 5th gens original stock harness and original stock Ecu.
So if the guy didn’t take that route to do that, then he definitely did some custom wiring which will make diagnosing a lot harder.
Does the car run at all? And if it does how good does it run? Just no Vtec?
Discussion Starter #6
I'll take a look today and see if the Vtec solenoid has one or two plugs. And as far as the car it runs good I haven't really tried pushing it yet
That’s good that it runs good, hate to go off topic but even though you’re driving it normal how does the F20b feel in the 5th gen? I have my original h22 now and i’ll be going F20b soon. But yeah either way check up on that Vtec solenoid, and also check if there’s any connectors from the harness in that area that aren’t plugged into anything.
Discussion Starter #8
It feels pretty good it was a little doggie on the highway. I got it a couple times it moves tires broke loose LOL. So that other ECU that was in the back seat is a p28 from a Civic will that work with the f20b and what do I need to do to get it correct?
I did a 1996 conversion to a JDM F20B, which I assume is what you have. You likely do need the P28 ECU, but the rest I would have no idea.
BUT:
I can give you name and number of a guy to call who WILL know exactly what to do and is the best Honda mechanic I have ever met. He did my work as many other places had no idea. You can call him and work out a consultation fee to give you the details. Trust me on this, I spent a LOT of time going to the wrong guys and he immediately knew what to do and my car runs PERFECTLY. With the V-Tec. Please tell him Rick from Boca referred you.
Gene - The Honda Doctor
(321) 945-8231
You can read his reviews, one of which is mine, on Google.
Best wishes!
Discussion Starter #12
Do update i tore the floor out of my prelude to get to ecu. I have a p06 in the car currently. Could that be the reason i have no vtec? I have a p28. Can i just plug the p28 in and run it? Or will i have to program it?
1 - 12 of 12 Posts
