yeah i found out my bumper sag is caused by a bent bumper support...apparently the previous owner had an accident that messed it up, pushing it downward...my only option now is changing it out completely...with time...i'm piecing retro's together right now:Rock: so i'll have to hold off on bumper saglooks great.... mugen exhaust = sex. I would dieeeeeee for one of those things. You should definitly fix that bumper sag, alot of people get that it seems. Ive been pretty lucky so far not to.
http://www.preludepower.com/forums/showthread.php?t=299987&highlight=bumper+sag
Meh, the bumper sag is minor!dude that little camera mount was absolute simplistic genius lol - i'm amazed i never thought of it - awesome work - keep it up lol -
cut a piece of pvc pipe thick enough where it wont bounce while driving and hitting bumps...drilled two holes for headrest to go through...then find a bolt that fits the bottom of the camera perfectly...sit in the back seat and see how you want the camera aimed..mark it, drill it, run the bolt, screw on the camera...if needed put washers so the camera stops spinning right where you need it..Meh, the bumper sag is minor!
and yeah no doubt, howd you make that thing??
Sounds quite simple, thnks bro i might make one one of these days lol.cut a piece of pvc pipe thick enough where it wont bounce while driving and hitting bumps...drilled two holes for headrest to go through...then find a bolt that fits the bottom of the camera perfectly...sit in the back seat and see how you want the camera aimed..mark it, drill it, run the bolt, screw on the camera...if needed put washers so the camera stops spinning right where you need it..
Your supposed to say... 'I always admire a good body, regardless of the make'. Fast and Furious FTW!!!! LOLNice job on the paint. I always admire a good paint job
