H22 All-motor build (non-Prelude...)
June 2020 UPDATE - Chassis purchased, assembly in progress. Hoping to have it tuned and driving before winter.
Dec. 2018 UPDATE - Went through the thread and cleaned up a lot of unnecessary junk. Trying to keep the focus on the engine build and not so much on the Accord. I joined this site for the H22 info, and feel a bit like I'm poking a stick at the focus on Preludes. The engine is something most people on here can relate to, though.
The chassis is a '93 Accord EX wagon. I used to have a sedan that I had swapped a JDM H22A into, and actually later went shopping for a 4th or 5th gen Prelude to serve as a daily during this build, but somehow ended up in an RSX. The goal with this build is about 245 whp/200 lb-ft naturally aspirated, but of course I live at 5,000ft+ elevation, so we'll see what my chosen parts actually yield. Lots of delays have kept putting this on pause, but in 2020 I'm finally closing in on getting it running.
Electronics:
- Hondata S300 w/Phearable base map (to be dyno tuned, of course) still need to pick up
- AEM gauges: UEGO, EGT, oil press., fuel press.
Intake:
Electronics:
Intake:
- K&N Apollo intake system for 70mm pipe
- AEM 70mm OD aluminum tubing for custom routing
- DEI gold heat tape; so far used on oil pan, but debating wrapping the intake pipe
- Professional Products 68mm Power throttle body for ITR, polished
- H22 Euro-R/Type-R intake manifold prepped by Rosko Racing (68mm port match)
- Hondata thermal intake manifold gasket
- Walbro 255lph pump w/install kit
- Rosko Racing rail
- Acura RDX 410cc OE injectors & pigtails
- AEM pressure regulator
- Ishino/Stone (OEM) top-end gasket set
- ARP head studs
- Supertech machine hardened valve locks
- Supertech titanium spring retainers
- Supertech 79lb valve springs
- Supertech valve seals
- GSC Power-Division B-series manganese bronze valve guides
- Supertech black nitrided dish valves
- New OEM valve spring seats
- '97-'01 spring-style LMA upgrade
- Skunk2 Pro 2 cams
- Skunk2 Pro Black Series cam gears
- H23 manual timing tensioner conversion
- Skunk2 cam seal
- Skunk2 "Skunk2 Inside" VTEC solenoid cover
- Closed-deck JDM H22A
- Mix of OEM and Fel-Pro bottom end gaskets
- Wiseco 11.5:1 pistons (re-sleeve, of course; one of my stock bores was scratched)
- Eagle H-beam rods
- ARP main studs
- ESP urethane mounts w/low-profile rear bracket
- ATI street damper
- OEM balance shaft seal retainer
- OEM block heater
- K-Tuned oil sensor adapter
- Skunk2 magnetic drain plug
- PLM HyTech knock-off 4-2-1 header
- I've also got a Spoon header; it bolts to the stock downpipe, but I want to have something made with a larger collector. One day I'll compare the two on the dyno.
- Vibrant 1197 EGT bung, stainless
- Vibrant 10355 merge collector, stainless 2.5"
- Vibrant 60804 "turbo" flex pipe, stainless 2.5"
- Vibrant 1194A O2 sensor bung x2, stainless
- Vibrant U-J scrap bends, stainless 2.5"
- Summit Racing 4' scrap straight, stainless 2.5"
- Catco 6906 cat, stainless 2.5"
- Vibrant 2.5" bottle resonator & 2.5" Ultra Quiet resonator - will experiment with both for sound
- Summit Racing 2.5" V-band connections x3
- Vibrant 2630 2.5-3" transition ("reducer" reversed)
- Kteller 3" stainless/mandrel piping
- Vibrant Street Power muffler, 3" in/dual 3.5" out
