1 - 9 of 9 Posts
Love the power of H
ok i was wondering if an obd1 h22 has a crank sensor? If it does not can you put a crank sensor in it?
They have 3, just like all other H22s.
Where they are is the more relevant question, I suspect.
Every vehicle produced has some form of crankshaft position sensor that either reads off the pulley or the flywheel. It helps the ecu determine TDC #1. Even with it failing, the computer will back up with the cam sensor(if equipped), h22's have one. You will just experience long crank times. Takes the ecu a little bit longer to determine TDC #1. Then it'll fire. Once running the ecu bases all timing ignition and injector of the cam sensor. Hope that helps.
All of the OBD1 H22s had all 3 crank sensors in the distributor.
so if my car cranks for a while before starting even when warm, i can suspect the crank sensor being the culprit?
Quite possible yes, not very often they fail on the h22's unless it's a high miler
it's something else then, I have less than 100k original miles.
Long crank time eh? Plugs with to large a gap will do it, any large resistance in secondary ignition. Check for cap and rotor corrosion. Fuel pressure and volume is a must check too.
1 - 9 of 9 Posts
