Hi guys! So I just finished F20b swap into my 01 SH. Wirings are correct, compression good, fuel good, ground is checked, Brand new distributor I am using H22 throttle body(map sensor) injectors H22, fuel rail h22, egr h22, fuel pressure regulator h22, iacv h22. everything is h22 i only used the f20b block and head. oil pump and crank sensor where installed. New injectors new dizzy, new wire, new spark plugs, new fuel pump,
???????It cranks but no start.
