1 - 10 of 10 Posts
i got MAPP gas to try and get that bolt off and NOTHING! map gas and like 120 PSI of air. i dont know what else to do
has anyone ever used the tool the service manual says to use? does it work?
we use a special socket that fits in the pully and jam one breaker bar to hold the pully still and another breaker bar with a extension to get the stuborn ones out!
yeah that special hodna tool helps alot,waht yur gonna need to do is after u fix teh hodna tool in palce break the crank pulley bolt with a breaker bar, but try to have soemone hold the breaker bar and extensions straight so that when u try to break it free the extensions dont bend up while yur putting force on it. and yur gonna need soemoen strong.
Idiotic Thread Locker!
on my beater accord during my timing belt change I had a friend hold a long crowbar point in the flywheel teeth, wedged against the tranny housing and then I used a 30" breaker bar to get it loose, after soaking the bolt overnight in PB penetrant.
we had one so tight (out of state car) that with one holding the bar against the body and 2 guys pulling down on a 4ft extension dending the bar! until POP it's loose.
1 - 10 of 10 Posts
