Alright guys. I'll try to make this quick. Short story. First of its one of those rare 95 SE preludes. H23a1. We had one of those small radiator hoses in the back start slow leaking while under pressure. The car started to overheat. We caught it relatively quickly, then found the issue and replaced the hose. Coolant was off color. We refilled and moved on. Coolant seemed to disappear, and the person who did the work did not bleed the system. It overheated for a short time again. When i say short time i mean less than 30 seconds.
Drain coolant, It's milky. I'm thinking head gasket because of the overheat. I put those head gasket tester kits on it. Two different ones, neither showed positive for exhaust gases. The coolant in the radiator stays clean until it goes through the engine. I pressurized the coolant system to 20psi and used a bore scope to see if there was any coolant bleeding off into the cylinders. None. Held pressure for 30 minutes.
I'm thinking maybe the oil cooler is contaminating it somehow? We just changed the oil and transmission fluid after all this and no signs of water in it.
I'm at a loss without throwing parts at it. Right now The thermostat is suspect so I'm replacing it since its cheap insurance.
Any other ideas on what is causing the milky coolant? Could it be residual?
edit: thermostat was definitely stuck or sticking randomly. Could not open by hand when I replaced it. So now it's trying to find out coolant contamination. It looks like milk is being put in the coolant.
