Are there any places on the A/C lines where leaks are common? My compressor does not come on anymore. I'm assuming that it worked when I first bought the car. I know the A/C blew cool on a warm day but on hot days it didn't work very well so that's leading me to believe that it's out of R-12 or at least very low.
I'm going to be taking the car to a local mechanic so they can check the pressure and run some dye through it to find the leak.
Can a typical home-mechanic change out an A/C line or is that something a shop should do?
Seals in the compressor, and lines that attach to compressor.
The seals go bad. Also, the compressor has overcharge valves on it. When the pressure is too great, the valves open to relieve it. Keeps from blowing a line or seal out elsewhere.
My theory is that this overcharge valve can spring a leak. This valve is located on the compressor. After 20 years, things happen.
My `88 S ac worked ok when I started driving it. Eventually, the pressure leaked out. So I replaced every stinkin seal/o-ring and it still leaks.
Can the typical home-mechanic change out something A/C related like the compressor or a hard line or should a shop do it?
Changing the compressor is simiar job to changing the Alternator, in regards of swapping them out. Its a little bit of a pain to get to, and probably easier from the bottom.
The tricky part is that it is a pressurized system, or was. If yours has already lost its pressure, then I would go for it.
If not, you have want to find a trusted shop, have them evacuate it, you change the compressor (to save bucks) and then take it back to be charged and probably converted, unless you do that yourself also.
