1 - 13 of 13 Posts
I'm betting this is a common problem, especially for the Eastern folks.
For the past week or so my '89 Prelude takes 4 or 5 times starting up before it stays running. The first few times, it starts but only runs for 1 or 2 seconds. Once it keeps running there are no more problems the rest of the day. Then next morning, same thing.
Gotta be some electrical device. Igniter?
:hmmmm2:
Try turning the key to the second click and wait a few seconds--then do this one or two more times. This primes the engine and if you listen, you should be able to hear the fuel pump.
I'm in VA and this time 'o year it's at or below freezing at night. I got this tip from Jason (EagleEyez) and do it every time I cold start my 3gp. It's helped the engine turnover much quicker every time.
Good luck.
Get your batt. checked and your alt.
also is your motor a carb or fuel injection
have you checked your main relay?
Replaced as new 2 years ago. That's the one under the dash on left side, right?
Are you keeping your foot off the gas pedal ? Throttle body FI engines do not have a CHOKE. The throttle plate acts as a choke so keep your foot off the pedal.
I never press the gas when starting
Good luck.
Have to give that a try :tee:
New battery earlier this year. Cranking is NOT a problem
SI, fuel injected, the only way to go
1 - 13 of 13 Posts
