1 - 9 of 9 Posts
it started happening a few weeks ago, when the car is cold and just setting off if i give anything close to 1/2 throttle the clutch slips in gear and i can basically rev the engine up and down. but after driving for a bit it goes away and in some instances ive been able to give it full throttle and it seems fine. i would think it would be the opposite, that it would slip more as you keep driving. if i baby my car it doesnt slip at all, and considering i just paid 3800 to get it fixed i am in no financial means to buy a new clutch. is it possible that something else could slip, maybe the flywheel is worn? i dont know much about transmission work.
Vrooom PSHHHH
Yeah, adjust the clutch pedal. You probably have way too much free play and it's not engaging completely most of the time
the 'lude makes me poor.
Yes, adjust the clutch pedal first; but if that doesn't do it I'd wonder if the crank seal is leaking oil onto our clutch disk. It's just a guess, but I'd figure if it did leak onto the clutch disk it would of coarse slip, and then after driving for a while you'd burn it off and it would grab until enough oil leak onto it again.
Do the simple things first, maybe clutch fluid is low/contaminated. A flush never hurts. The rear main seal wouldnt leak onto the clutch disc, thrers a drain on the lower flywheel cover for that very reason. Put up the parking brake hard, put it in 4th and rev it up3-4k, let out the clutch pedal...if stalls than the clutch is grabbing just fine. What work did you just have done? No noises or anyting?
Really? make sense, but I remember a few threads where people said it happened to them, and a few more threads where people suggested that that might be the problem.
Its possible to get some sling, but it would have to be a horrible leak. It would have to make its way all the way around the flywheel. Since it happens when the car is cold, read: oil is thicker, I doubt its b/c of a leak. If it slipped a bit after some highway driving than maybe. Its got to be fluid or master or slave going out.
1 - 9 of 9 Posts
