1 - 4 of 4 Posts
So ive got an M2B4 Gearbox sitting in my old Lude on block's at the moment im wanting to take this out an switch it with my new Lude running an M2A4 Gearbox, just wanting to know if axles will be an issue at all and if theres anythign major i need to consider when doing this?
I have tried to search on this but couldnt find alot other than the clutch writeup.
Any Info would be helpful.. cheers guy's.:mrgreen:
Axles and all of that jazz should be fine.. The only thing that you need to consider is making sure that you put in the right oil. I'm not sure what kind of LSD comes from the factory, but that'd be the only thing I'd look into.
they both have the same ratios, only difference is that the m2b4 has lsd and the casing is slightly larger. if you are trying to swap out the lsd from the m2b4 into the m2a4 casing its not gonna fit.
about the oil, i am using royal purple tranny fluid, works better than the honda mtf i had before.
1 - 4 of 4 Posts
