I took this center tail off of a junked lude. My plan is to open it up, secure an led strip behind the PRELUDE and then wire it up to light up with the brakes.
Firstly, I need to know how to open it. It has an epoxy-like glue everywhere. Behind the clips, around the edges. How can I remove this glue to open the tail?
Secondly, which wires will I need to tap to light up with the brake lights? Is there a way to have it passively lit with all the lights on, then brighten after the brakes are pressed? (I'm not good with wiring) Would resistors work?
