1 - 20 of 21 Posts
I don't know if this known or not, I did not see it in the interchange sticky.
For those using factory polished aluminum alloy wheels but missing a center cap or two, you can use one for a 2000-2006 insight. One came into the shop the other day, and as I try to test fit every large Honda cap to my car, I did so with this one. It is a direct duplicate. My cap fit the insight, the insight cap fit my prelude. The "H" is even identical. These caps are still available from Honda.
Specifics:
My car-89 SI 4WS with 6 spoke blades part # 42700-SF1-A91 (right) and part # 42710-SF1-A91 (left).
My center cap # 44732-SF1-A90
Insight-2001 auto w/o AC wheel part # 42700-S3Y-E31
Insight cap #: 44732-S3Y-010
For those with the frost white 5 spoke blades found on the 90-91's, you can remove the outer aluminum covering of these caps and paint the plastic white and the "H" black for a factory replica of cap # 44732-SF1-A22. The center "H" is already molded into the plastic under the aluminum.
Hope this helps.
Great find!
This should probably make it into the FAQ so it doesn't get lost in oblivion. There are a lot of 3rd gens running around with missing center caps.
Just broke the cap on my '89 4WS hitting a pothole on the highway. I managed to retrieve the cap, but the plastic insert lost too many tabs to stay on. Figured there might be some useful info here - but no way someone found a way to buy NEW ones! I just ordered one off ebay for $15 (that includes shipping!!!) - no words to express my gratitude if this works! Prelude Power comes thru again - really appreciate the board and all the expert info available here - THANKS!!!
Discussion Starter · #12 ·
:wink3:
Has anyone purchased the Insight caps, part #44732-S3Y-010 for their 88 or 89 saw blade wheels? I just got a set in and the caps themselves are the same size as the original caps but the tabs are spaced just 1/8 inch further out preventing them from fitting.
2009 +/- Honda Civic Hybrid also have the same center caps as the Prelude. I have a couple from a salvage that I secured about 6 months ago.
Yes it is a good find, and should probably be stickied. I',m not sure of some of the Accord and acura legend caps. They may fit but since I don't have 1st hand experience to answer your question I will refrain from a definitive answer
The caps for the ludes should be pretty plentiful in the wild.
Well I hadn't heard that before about the civics. I see they have similar wheel. Yeah a chance of me finding a Insight at the junkyard is slim to none. The drawing of the civic center cap shows a circle around the "H" but I don't know if they are all that way. Here is interchange for civic hybrid according to hondapartsnow.com
06-2011 civic hybrid 4dr mx the text isn't complete but I think this includes hf with hcm engine.
2012-2015 civic hybrid 4dr mx or 4dr hf w/ hcm engine.
I don't know anything about these modern civics so I just posted what I read.
As far as the 90-93 accord that are all over ebay and even aftermarket reproduction I have been told onhere they don't fit. They will have a sm4 in the middle of the part number.
Might need to give these 44732-S3Y-010 a shot. I'm missing 2...
1989 Accord LXi Coupe; 1989 Prelude 2.0s; 1964 Dodge Dart GT: 1993 Kawasaki ZX-11; 1982 Honda CB900
WOW!! The entire active Membership of the board here all @ once <eg>
1 - 20 of 21 Posts
