1 - 11 of 11 Posts
i just checked my CEL and its ( p0420 catalyst efficiency below threshold ) i was told this was because of my high flow cat, is there anyway to correct this problem by still retaining my high flow cat? or do i have to use the stock one? thanks alot
tobie
oh and yes ive tryed resetting, it comes back with the same problem =0)
bangin' gears
tobie
how old is it? It could be that your o2 sensors are just really dirty and having the car run kinda sluggish.
you could always convert to obd1 which would take car of the o2 sensor in the cat. prob wouldnt be a bad idea seeing that you have some headwork done too.
how do you like those cams? i am thinking about going with the s2 stg2 myself but i still have emissions to think about.
i dont think its ever been changed.....
car doesent seem to run sluggish thow
i guess ill try replacing it, should i get OEM or is there a aftermarket one?
go to www.sparkplugs.com and you can get an OE Denso O2 sensor for $40
HipHopHeadd
Probably needs oxy sensors. Look into getting a simulator or wideband air fuel meter :).
I saw a thread somewhere about someone using a a spark plug non-fouler and making it fit on an oxy sensor. Anyone seen this?
tobie
that will come up almost everytime you put a aftermarket cat on as the OEM one burns alot cleaner then the high flow one , there are a few things 1 use the fouler trick ,2 use a O2 simulater and last convert to OBD1.
1 - 11 of 11 Posts
