My car runs like shit once its warmed up it putters a lot like its going to die.
When was the last time you did a tune up(spark plugs,cap, rotor, oil change )?
Are there any codes is the first quesetion to start with.
If no, then what was the last known work on the car before it happened.
Discussion Starter #4
I am going to see what code its throwing, just had timing done again because last guy was too retarded, check engine light was on last i checked so
lol man might wanna check that your timing components are all in sync, if your belts too loose y our exhaust cam can skip a tooth and youll get a random misfire at idle... this would be the least of your problems tho! better be sure everything is good timing side anyway... im a newb mechanic but thats what sounds like is happening anyway
Discussion Starter #6
Checked the codes, Forgot to adjust tps and Iacv went bad :D glad its not worse, Ill get a video of it running before and after
