Interior
ICB Motorsport 5 Speed Tear-Drop Weighted Shift Knob
JTC Customs Short Shifter
Shayspec. Solid Forward Gate Bushing
JDM Red Stitch Shift Boot
Broadway Convex 2X 300mm Mirror
AEM 30-4100 UEGO Controller Gauge
LED Conversion
EDM Foglight Switch
Metal Gauge Rings
Exterior
JDM Honda Access Door Visors
LED Reverse Lights
LED Parking Lights
JDM Replica Fog Lights w/ 3000K Morimoto HIDs
JDM Red H Front and Rear Emblems
Debadged VTEC, Type SH and Prelude Rear Stickers
Tinted Windows
Engine
H23A VTEC
Skunk2 Pro Series Intake Manifold
Skunk2 Alpha Series 70mm Throttle Body
Blox Racing TPS
Stock MAP Sensor
Skunk2 Pro Series Valve Springs (B-Series)
Skunk2 Pro Series Valve Spring Seats (B to H-Series)
Skunk2 Pro Series Titanium Retainers
Stock H23A VTEC Cams (For Now)
Kaizenspeed H22 Tensioner (V2)
Kaizenspeed Walk Blocker
Kaizenspeed Balance Shaft Delete Kit
H23A VTEC Distributor
H23A VTEC Oil Pump
Rywire Distributor Adapter
H22A4 Fuel Rail (For Now)
H23A VTEC Fuel Injectors (For Now)
H23A VTEC Valve Cover w/ Shaved Throttle Cable Mounts and Lettering
Hondata S300 on P28 ECU
Vibrant Performance Racing Header
Innovative 75a Motor Mounts
Kaizenspeed V2 Tensioner
Kaizenspeed Balance Shaft Eliminator Kit
OBX 3-inch CAI w/ Vibrant Performance couplings and T-Bolt Clamps
AEM 6" x 5" Dryflow Air Filter w/ BPi Flow Stack and AEM Dry Flow Air Filter Wrap
NGK Blue Spark Plug Wires
Speedfactory Thermal Intake Manifold Gasket
Mishimoto Radiator w/ Fan Shroud and Slim Fans
JTC Customs Cooling Plate
Transmission
T2W4 LSD Transmission
Hybrid Racing Performance Shifter Cable Bushings
Stock SH Axles
Exedy Stage 1 Clutch
Competition Clutch Forged Lightweight Steel Flywheel
Exhaust
DEI Header Wrap and Black High-Temp Silcone Spray Paint
Cometic Exhaust Gasket
2.5-inch to 3-inch Coupler
3-inch KTeller Stainless Steel Piping
Two 3-inch x 18-inch Vibrant Performance Resonators
3-inch Inlet x Dual 3-inch Outlet Flat Black Vibrant Racing Muffler
AEM Wideband O2 Sensor
Brakes
EBC OEM Replacement Rotors
EBC Redstuff Brake Pads
Suspension
Ksport Kontrol Pro Coilovers
Neuspeed Front Upper Strut Bar
ST Suspension 1-inch Rear Sway Bar
Energy Suspension Front Sway Bar Bushings
Innovative Mounts SH Front Crossmember w/ Energy Suspension Bushings
Wheels
Yokohama S.Drive 215/40R17 Tires
Enkei Racing PF01 Rims - White 17x8 +50
ARP Extended Studs w/ 15mm Spacers in the Rear
Blox Racing Extended Open Ended Lug Nuts - Gold
