1 - 18 of 18 Posts
alright which bolt do you turn to bleed the clutch? theres a few under there and i dont wanna touch anything i shouldnt.
It's on the slave cylinder. Looks identical to a brake bleeder.
mounted right in front of of where the engine meets the tranny.
I Miss My BB2 :'(
omg do not touch your car until you find out more info!!!!!!!
slave cylinder:
I Miss My BB2 :'(
now you need 2 people to bleed the clutch BUT you can do it by yourself which is 100x harder.
first: unscrew the 8mm bolt (just break it open. you dont have to take it all the way out. just one good turn will work fine.)
second: push the clutch pedal down and hold it there. (it may stay anyways but sometimes it wont until further into the bleeding process.) if you let the clutch pedal pop back up then it will suck air into the system which is not good. but if you do then repeat this process until all the air is out.
third: tighten the 8mm bolt.
fourth: pull the clutch pedal back up
fifth: pump the clutch pedal a few times
sixth: repeat the process until satisfied.
hope this was helpful. rep wouldnt be minded ;)
thank you very much, ill def. get on this now i know how to do it hhaha
I Miss My BB2 :'(
i do that except take the slave cyl off and hold it up it helps air get up to bleeder and takes less time
yea i never thought of that. good thinking ;)
but im just too lazy to take the bolts out lol
there is no rubber nipple its just a screw off kinda of thing. a tiny socket would make it easier.
and dont let the clutch fluid resevoir get empty, you might fudger up your master cylinder.
I Miss My BB2 :'(
8mm wrench
I Miss My BB2 :'(
i think it might be stripped cause it wont even budge
am i better off getting a new slave and bleeding it?
if you wanna pay that money man. just get an 8mm deep well socket, put it on your ratchet, find a cheater pipe and go to work on it. remember righty tighty left loosy lol
1 - 18 of 18 Posts
