UPDATE 3/1/13: Its been a long time coming for this car, but as of March 1, 2013, The car is running, titled and plated. Many more updates to come!!!
More pics on Page 3 and 4
Please chime in with remarks and suggestions.
I thought about giving up on this car many times, but im not going to. I want to finish this thing and have a dream car. There is much more work to be done, but im going to do it.
Now that im going to be on sequestration for one day a week, Im going to dedicate those days to working on this car.
So, to make a long story short, i bought an 88 4ws lude back in august of 07 with either the intention of turbo'ing it or going H22 route. Well, i chose the later due to the fact i found the perfect doner car-an H22 swapped 92 lude. here are the pics of the doner car:
after acquiring this car, i found out from a friend that it once belonged to a member of the local honda club. So, when he found out that i had the car, he wanted it back. Well, i told him-it will be without the motor" So, with the help of a good friend who has done alot of motor swaps, we made a deal-i get the H22, he gets the car as a roller and my buddy will do the swap for me (i just finished a masters degree and didnt have time to work on it myself). Deal was set!
So, during the process of the swap, alot of issues came up with the car and the friend doing the swap having major health issues (which i will talk about in a minute). He got about 80% of the job done, but then found out he has to have open heart surgery. I just moved out to New Mexico and i had the intention of flying back to St Louis and driving the car back once it was done, but no dice. So, with that said, i told my buddy i would have the car hauled out here. So, here is how it sits today in my garage and how it came in on the hauler:
Im just really glad she is back and im really wanting to get her running. i have a bunch of friends here that are going to help me with finishing it. here is a list of what still needs to be done
Alt belt-since i deleted the AC, this will have to be changed (shorter belt)
PS Belt-its going to be a tight fit in there but if i use an H23 belt, i think it will work.
PS hoses-again, i have to do some tinkering with them to see where they are going to go.
TPS and VSS sensors-on the harness they are disconnected so i need to figure out some things with those
Dizzy-the motor has an external coil but the harness was made for an internal coil. Looks like i have to get an internal coil
ECU and jumper harness-need to install
Fuel line-looks like i need to modify it a bit
Shifter cables-the bracket on the tranny doesnt work right with the cables-any suggestions?
Radiator hoses-i remember Team123 said that the upper hose works, but it doesnt seem to line up right. I will need to make a custom hose for the lower.
man if only you where closer i would come out to help you get this knocked out and you wouldn't have to miss the cupcake meet! working on getting a couple ludes up and running before the meet! friends 98 lude (shattered ringlands) i got the motor reassembled but waiting for act clutch to come in. a friends 99 lude auto (4th slips to no where) but manual swap parts wont come in on time. another guy has a 4th gen with a h22 swap with wiring issues!
im just crossing my fingers that nothing major goes wrong with mine :/
hey man, click on my cardomain link and you can see a few things that I had done, that may or may not help you out.
The fuel line, i just bent it slightly and it worked fine.
you'll have to lower the coil, if you keep the external one, because it'll rub a little on the hood.
as for the shifter cables...which are u using? You have to use the right combo:
5th gen cables and shifter -or- 4th gen cables and shifter -or- accord shifter and cables...You can not use the 3rd gen's shifter and cables...Hope that helps
I am using the 4g prelude cables and a CB Accord shifter. I know its an odd combo, but from what Team123 says, it can work. However, the shifter cables are not secure since there is no bracket.
Also, since this is an 88, the electronic VSS is removed so i need a bracket to keep the cable in the transmission (1funryd got any yet?)
So, i have a few questions about the rest of this process-alot of the write-ups do not have this information:
Alt belt-since i deleted the AC, what is the part number for the shorter belt that i need to use?
PS Belt-its going to be a tight fit in there but if i use an H23 belt, i think it will work-does anybody know the part number for the H23 belt? is anybody using something else?
PS hoses-again, i have to do some tinkering with them to see where they are going to go-anybody have a remedy for this? custom bracket?
Dizzy-what are you guys running? I have an external coil on the motor, but the harness is made for an internal. However, i have been told i can change this and run an MSD-type. true?
Fuel line-looks like i need to modify it a bit-what is everybody doing for this? just bending the B20 one?
Shifter cables-the bracket on the tranny doesnt work right with the cables-any suggestions? What is the work-around for this? I tried the H22 and H23 backets and they dont seem to work. Is this because im using an Accord shifter with 4g lude cables?
Radiator hoses-what are you guys using for the upper? I hear that the 5gen lower house works perfect?
I will did through my stuff this week end, but the best way to get your belt size is too take a think string or twine, and use it as a template to wrap around the crank pulley and around the powersteering pulley and tie it off, make sure that you give the string some slack to compensate for the tension when the time comes to tighten the belt down.
Do this for both and take that string to your nearest belt shop and they can match it for you, just let them know how many rib belt you are going to use.
Thats all there is to that. I do have the belt stock numbers but there in my closet kinda of buried, so it will have to wait to the weekend.
As for shiftlinkage, you need to use the same linkage with the same shifter, they differ slightly and can cause the issues you are coming across.
As for the fuel line from the fuel filter, you need to bend it a littel to get it to fit right.
I used my OEM upper Radiator hose and just cut it to fit, but I used the H23 lower radiator hose and it fits perfect.
The rest I will leave for the experts on the Distributor and internal coil stuff.
I dont have the origonal clip for the VSS, unless its in the parts box that the guy gave me when he did the swap. The cable is just put into the H22 tranny with no clip.
I will work on the belt issue this weekend-i think somebody said an H23 belt would work for the PS?
I will need to get that ALT belt definately measured, unless somebody else knows the dimensions?
Well, looks like i will have to hunt for a 4g prelude shifter then.....ugh!
I tried to cut the OEM hose to work, but no dice-did i do something wrong? I hear any H22 lower hose works for the swap.
No real update on the car-its been sitting for over a month now. Money has been tight so its been put off till tax return/first time home buyer check comes back.
So from the looks of it, i will need to get a 4g prelude shifter, since i have the cables from one.
So, the old stock cable VSS bracket works for the H22? Right now, the cable is just kind of stuck down in the tranny.
I have to bolt up the Alt and PS pump then measure the belt length for the alt. What are you guys running for the PS belt? 4g h22 or h23? I hear that the h23 belt is a bit more skinny?
So, all i need to do is bend the fuel line a bit? it looks like it would crimp to me, but i will give it a shot.
also, what are you guys using for your shifter cable brackets? stock? the guy that was working on the car said the stock one didnt work-maybe thats because of the accord shifter?
I have been working here and there on the car-still need alot to go. here is a list of parts i need as well as issues still with the swap:
Dizzy-motor has an external however Rywire made the harness for an internal. any ideas to remedy this issue without having to buy an internal dizzy?
power steering belt-what are you guys running with your swaps? stock? i look like im going to rub the inside of the engine bay if i use a stock 5 rib. Maybe i can get a custom 4 rip?
alt belt-need custom since AC is removed.
Relocate battery to the trunk-any writeups on this? also need some wire and a battery box for the trunk
spark plug wires-any recomendations?
4gen prelude shifter-the guy that installed the shifter put an accord shifter with 4g prelude cables. So, now i need a prelude shifter.
shifter cable bracket for H22
relocate power steering reservoir-i think im going to delete the window washer reservoir to make room for this.
VSS issue, since i have an 88 with cable spedo-1funryd i think is working on a custom bracket for us 88-89 users
fuel line-it looks like the stock B20 will not work? The bend at the fuel rail end of the line isnt enough for it to fit. What are you guys using?
Thats about it. I installed a new VC gasket, TPS sensor and Blox cam seal today.
Hiya. I bought this car on February 28, 2018 and I'm in the slow process of bringing it back to "fresh off the boat" condition. I'm the second owner, and I plan on keeping this car all original. I paid $2,873 with tax, tags and title. His name is Atreyu.
Engine/Performance
Stock B20A5
Stock 4AT...
Ok, here's the start of my Type-R swap journey. Some probably know how I acquired the motor for this swap, but for those who don't, Im working with a 97 Spec JDM B18C-R Engine and trans. I dont have the greatest rebuild pics, but we really didnt do too much to it. I just wanted to refresh the...
Ladies and Gentlemen,
Welcome to my build page. I was collecting parts for this build since I got the car (4 - 5 years now), my biggest problems not to start earlier was TIME and SPACE. Finally I got the garage, so let's start.
There she is, pretty much in the same condition as I picked...
As some of you guys know, I have a lengthy build thread that has become a bit disorganized over the past couple of years (plus progress has not been nearly as fast as I anticipated), so to keep things more up-to-date and organized, here is a new thread! :D
I purchased the Prelude new in 98...
Hi All,
As I'm sure like most of you, I have a special place in my heart for Preludes, specifically 3rd gens.
Brief synopsis of the story: The first car I ever owned was an '87 Ford Tempo. Then, I found a white '89 Prelude Si 5-spd, and was able to make it my second-ever car, from late my...
