1 - 13 of 13 Posts
Hey guys i'm getting a new tachometer (aftermarket) cuz mine is not working and i was wondering where is the best place to install it ( like on the left side of the steering wheel or on the right ... ? )
Why isn't it working. I would fix that even if u have to buy a new cluster. No offense it would look gay a big tach working next to your dead tach. If you must install it. Be old school and install it on your hood!!!!
my friends got a small 3 inch tac. mounted by his sterring col;um but i guess a-piller would be alright lookin. but yeah i think you should fix your stock one.
Umm i have no idea how to fix it ... i really want to stay with my stock one...any suggestions what can be done so it can work again ? it's only the tachometer that is not working i have no idea what is the problem.
Where is the best place to put an aftermarket tach?
IN THE TRASH!!! :tounge2:
just fix the stock tach, it will probably be cheaper an it won't rice out your interior. I've seen them installed in a few ludes and they look terrible..............like a civic owner. roflmao
Discussion Starter · #9 ·
I would pull up the carpet up and check the RPM wire from the ECU.
I'll do that.
I would install it directly into my brain, so that I can have an RPM indicator through my nervous system!
Hahaha that's a good one.
So from what i hear nobody likes aftermarket tachometer ( i really dont like it neither but i want mine to work so bad :( ).... i'll check everything i can on it and try to fix it. Thanks guys :)
it depends on what size tachometer you are trying to install.the 5th gen is the hardest to install a tach in my opinion because the windshield is so sporty and is at a weird angel.so i think the best place is either on the a-pillar or if that doesnt work there is another good place.on the dash above the driver side air vent closest to the driver door there is a vent at the top of the dash that pops out and reveals a good place to run your wiring up through the dash.but try and fix ur stock tach first and let me know
Fix the one in the dash, it's kind of silly to install an aftermarket one when the stock one doesn't work.
1 - 13 of 13 Posts
