Is this possible with stock b20a5 bore. If so, which headgasket?
Well that means you use the B21 period. You don't have to worry about the valves hitting the gasket they don't go that far down. If they did they would hit the block regardless which gasket you use. If you used a B20 head and gasket on the B21 block the pistons would destroy the gasket in no time due it's bore being bigger and it hanging over into the combustion chamber.tsiah said:*shrug*
Im still going with my 'match the larger bore' theory....
makes sense. wtf do i know im bored and should be getting to work but reading threads like this makes me lateSlipslap said:Well that means you use the B21 period. You don't have to worry about the valves hitting the gasket they don't go that far down. If they did they would hit the block regardless which gasket you use. If you used a B20 head and gasket on the B21 block the pistons would destroy the gasket in no time due it's bore being bigger and it hanging over into the combustion chamber.tsiah said:*shrug*
