Hello! It's my first topic and second post on the forum!
So, today I used an obd1 jumper to see the CEL (also atts+abs) codes. Check engine or abs light didnt blink, but ATTS did many times. So I counted them all and got these codes:
19 - Steering Angle Sensor (for some reason it skipped this code sometimes and repeated the 3 latter)
33 - MAP: Manifold Absolute Pressure Sensor
35 - Reference Voltage
43 - ECM Communication Line
Can some of you prelude wizards tell me what is causing these issues? I would be very thankful! I'm a newbie when it comes to things like this.
Couple of weeks ago I saw my atts light on. I shut my car and started it again and the atts light went off. It was just this one time and havent seen it once afterwards.
I should note that my Lude burns a lot of oil and gas and it failed the HC emission test last time. Maybe it can explain something?
Sorry for my bad English.
Greetings from Finland!
