1 - 2 of 2 Posts
Hello all.
First post here have exhausted all resources before troubling you kind folks.
1994 Honda prelude s
F22a1 motor with M2L5 transmission.
Not an easy transmission to remove my first 2 rounds this is round 3 pulled the whole motor doing some overhaul with the engine as well (irrelevant got that covered)
My issue is the input shaft bearing on this transmission is bad, as far as I can find online I only see a full kit of all 5 bearings by syncrotech. I’ve been around the block transmission is healthy not going to be messing around with the other bearings. Does any one have the part number or a direct line on the bearing.
Not looking to pay $260 for the full kit,might be worth it but that’s besides the point of this post.
Thank you in advance.
Administrator
You can always go to your local Honda dealer or online Honda retailer and order the bearing.
91002-PG1-018 - bearing
91216-PH8-005 - seal
1 - 2 of 2 Posts
