1 - 7 of 7 Posts
you need to provide more info.
what engine did you swap in specifically? engine code helps. what ecu are you using?
what exactly are the problems?
i have put a f20a 2.0 dohc si jdm motor in place of a f22a sohc 2.2 but i now have a dual over head cam coil distributor and ecu out of a 1990 prelude si b20 (the people at nopi said that would work
I think the people at nopi are smoking crack.
In order for your engine to run properly, you need the right ecu for that engine.
I would ask for that in the 3rd Gen section, theyre the ones with B20's...
does anyone have a pin chart for a pk3 ecu for a 2.0 si?????
Why the hell are you using a 3rd gen ECU? The correct
ECU for this motor is the PT2 which is another JDM ECU. You could run the P14 from an H23 but youll will be throwing a Knock Sensor code.
1 - 7 of 7 Posts
