1 - 3 of 3 Posts
Well I searched through the 4th gen area and have come up with a few things.
TPS seems to have a few issues
code 43 is a bitch
exhaust leaks before the o2 sensor are common
This is the two things that lead me into my questions, if I had an exhaust leak at the down pipe and header joint then fixed it would it possibly have fried my o2 sensor.
Also is there a way to "reset" the TPS?
Thanks
Devin
If your car is throwing a code for the TPS, chances are that you will need a new one. Make sure the wires are good that go to it, make sure it's plugged in, etc. You could always unplug the battery for an hour or 30 minutes, enough time for the PCM to reset and see what happens...
You should get a code if your O2 sensor is bad too, but it still could be bad.
1 - 3 of 3 Posts
