1 - 3 of 3 Posts
As the title says, do I need an alignment after swapping the shocks with OEM replacements? The springs are also OEM. I'm trying to understand why I need to, but the shocks aren't a locating member for the suspension system; it's merely supporting the suspension in the Z-direction. I didn't touch any eccentric bolts on the arms, only the hardware that mounted the damper and nothing else.
May someone confirm this?
Nah, you should be fine.
1 - 3 of 3 Posts
