I thought I would share this with the group. I did a project on my 90 Si 4ws last weekend, I built a new air filter element. Let me tell you my line of thinking to get to this project.
My goal is to keep this car relatively stock, at least in appearance while making small upgrades to optimize it's performance and reliability. I love it when I show people the engine compartment and they see a stock, unmolested car. No day glo wires, shiny ram intakes, etc. It is pretty rare to see such a clean car of this age that has not been assaulted.
As far as filtration goes, stock paper filters do a much better job filtering small particles over gauze type elements (K&N, etc.). So much better that I refuse to run a K&N. But, K&N's and other quality filters of this type do flow much better than paper, especially at higher RPM's. So what to do???
I was cleaning the foam filter out of my KTM and it hit me, a foam filter element.... Off road vehicles from dirt bikes, to quads, to trophy trucks all favor foam type elements for their superior filtration, excellent flow properties and ease of cleaning/care. So I went to work.
I hacked a stock paper filter for my car, removing the paper element from the perforated metal core that supports it. I purchased some UNI universal filter foam that comes in a sheet ($16). I cut it to fit and wrapped it around the perforated core, gluing the seam with gel type super glue. I then oiled it with my favorite filter oil, No Toil, and installed it in the factory filter housing. I previously removed the factory small snorkel that runs up across the top of the radiator and replaced it with an accordion style air tube that plugs into the cold air feed of the passenger headlight assembly. To the unknowing eye, it looks factory.
Results. The car seems to be a bit quicker responding to throttle inputs and it also seems to pull a bit harder up higher in the rpm range. I do not know if a dyno would actually show any improvement, but it did not hurt at all. Next time it needs cleaning, it will pay for itself by not having to purchase a replacement.
Just a fun DIY that worked pretty well and took me about an hour.
