Check the drive belt condition. If its worn then it might be slipping which is why it's only effective at higher RPM.
Youtube has a lot of beginner type videos to diagnose issues.Looking for some help diagnosing an a/c issue on a 90-91. It really only works when I get up to speed on the highway, blows cold air. But it won’t last more than 10 mins. When I got the car it worked some what. The compressor did make a rattling noise, but it did blow cold. At idle the compressor will not cycle.
Thanks SeanYoutube has a lot of beginner type videos to diagnose issues.
The problem is actually very common. In fact, it is very simple to deal with. You only need to clean the water tank and condenser. Because the water tank and condenser are dirty, the air flow is large when the car is driving at high speed, so the heat dissipation is normal, but When the speed is low, the heat cannot be dissipated in time, which will lead to poor cooling effect.Looking for some help diagnosing an a/c issue on a 90-91. It really only works when I get up to speed on the highway, blows cold air. But it won’t last more than 10 mins. When I got the car it worked some what. The compressor did make a rattling noise, but it did blow cold. At idle the compressor will not cycle.
