1 - 13 of 13 Posts
When I turn on my A/C it never blows cold. This sucks.
I Recharged the system and nothing.
Would a fuse be the problem, and where would I find them? The heat never gets really hot either. Kind of like warm/lukewarm, unforunately so is the Cold setting (still cooler than the hot setting tho) :(
Any help is appriciated, don't really know where to go from here.
ludehaze said:
Could have a leak in the a line.. also compressor could be bad..
Ugh. What parts would I need to fix the compressor? I don't know where to look on the majestic honda site.
It could be an a/c high pressure switch. When you turn on the a/c can you hear the a/c compressor kick on?
First of all refrigerant(freon) never goes bad.. onces its in the system you should never have to replace it.. doing so is just stupid.. but yeah as for replace'n a compressor, just replace.. If I were you I'd take it to someone. Cuz if you don't know what your doing then you could just make it worse..
good luck though
i had a leak in one of my hoses. replaced it, recharged it, and now i'm good to go. check to see if your compressor kicks on. also, check to see if the system holds the charge when you recharge it. mine had a huge hole, and leaked like a mofo when i tried recharging.
yeah do all that rok3479 said.. but if all that don't do anything for you, then you may have to bow down to leting someone else do it.. again.. good luck
1 - 13 of 13 Posts
