I tried searching for someone who capped off their EGR. Does anything need to be done with the ECU because now there's a dead plug hanging there?
When I put the replacement junkyard engine in (b21 for a b21) I'm getting a really bad idle and I wanted to check the timing but the RPM's won't stay steady below 2k enough to get the timing light on it. I'm going to try the adjustments found and tricks for the irractic idle on the board tonight when I get home but I was wondering if it could be something else.
Only thing I did differently before putting the engine in is remove the egr and by-passed the tb/intake coolant lines. No leaks on any of the vacuum hoses, checked with carb spray.
Does the Ecu have to be refreshed even though the battery was out for a week?
