1 - 20 of 132 Posts
-im almost done with the motor built after a year now so i decided to make a thread. im about due anways. long story short; i bought the car about three years ago. a year in, she started to have asthma attacks and spat out some lovely bluish white smoke. had it checked and compression was all outa wack and i needed to new piston rings. so i decided to rebuild. the cars been sitting for about a year now. ive been slowly accumulating parts. i go to school in another state so i was in no rush anways.
-for starters im taking out the h22a for my built h22a4. i replaced just about EVERY bolt, washer, gasket, and part straight from honda. the head has been hot tanked, 3 angle valve jobbed, and ported & polished. the bottom has also been hot tanked and crank has been micro polished.
- when i first gotter. back when she was innocent and untainted.
most of the parts pictured are old and already in the motor im building.
JGE dual valve springs & JGE titanium retainers
JGE flat-faced, black nitrade coated valves
supertech bronze valve guides & supertech vittone seals
crower stage II camshafts
skunk2 cam gears
87mm Cometic head gasket
eagle H beam conrods
- also have type s pistons, acl bearings and arp head bolts, and honda piston rings that i didnt get a chance to take a picture of. there also already in the motor.
skunk2 pro-series intake manifold & skunk2 pro-series 70mm throttle body. i installed before the car farted out on me so im reusin it.
injen sri. i have a bpi flowstack comming in the mail as i type.
a fresh set of motor mounts
some hyperflex inserts to go with the motor mounts
-for shits n giggles not necessarily needed for the build-
NRG torque damper
random voltage stabilizer
noname oil catchcan
aaaaaaaaaaaaand heres a recent pic of the car spooge-covered in different hues of primer. tryin to fix the high/ low spots. there every gawddamnit.
motor pics to come soon. :Rock:i should be going back up to the shop after new years.
nice keep up the good work cant wait to see it when its done
flat black will look really nice
Discussion Starter · #17 ·
1 - 20 of 132 Posts
