1 - 2 of 2 Posts
My sunroof drops down and i hear the motor is running but won't retract. I bought the tool to manually retract it but it seems jamed and won't go back. any ideas??
if you can get a friend to to gently pull on it while you crank it you should hopefully be able to get it shut. Probably stripped gear. Mine is the same. I have several used motors but have not got it replaced. You have to take the headliner down and I think the sunroof pan/assembly to.
1 - 2 of 2 Posts
