The body and engine damage totaled the car. To a buyer who can rebuild engines, it's worth more than what a junkyard would give for it.
the engine damage is completely fixable, just need a b21 for the parts, none of the actual block was cracked just the part where the dizzy mounts to the top, it’s just a replacement, body damage is nothing it’s just a panel replacement as well as the light damageThe body and engine damage totaled the car. To a buyer who can rebuild engines, it's worth more than what a junkyard would give for it.
You did a lot of damage to your car. I can tell the engine is fucked and the frame is slightly tweaked just from the pictures you showed. I know if I started taking things apart I'd find more problems. Good luck, I'm curious what you end up selling it for.the engine damage is completely fixable, just need a b21 for the parts, none of the actual block was cracked just the part where the dizzy mounts to the top, it’s just a replacement, body damage is nothing it’s just a panel replacement as well as the light damage
