Idk if this has been asked or not I'm at work don't have alot of time to search. I was given a 89 prelude aws for free has the 5speed manual. The 2.0 dohc engine is missing. I have a jdm f22b dohc motor I heard about swapping the engine in but what all do I need? I'm doing all the work myself at my shop I just need a parts list
Yes, this has been asked a million times before.
H22 swap is the same as the F-Series swap.
You will need the following parts:
1. My H22 swap kit
2. My conversion harness(unless you know how to wire it up yourself)
3. My traction bar and skid bar
The rest is in the parts list that I created years ago, in the FAQ stickie above - H22 Swap Checklist - Parts to get...
My site: www.1funryd.com
My email: [email protected]
Ok so update I have the 2.0 head but the block met the wrong end of a rod. Can I get a different block setup and put my head on it?
Your only option if you are not willing to swap is to find another B20a5 or A and swap it out.
No other Honda blocks bolt up to the a5 or the B21a1's.
Here is a comparison photo of the Newer B-Series too the bastard b.
B20b/z and B18 on the left and B20a5/B21a1 on the right.
Motor vehicle Automotive tire Wheel Tire Automotive design
As you can clearly see they are not even close.
Will a b16 engine bolt to my transmission?
Again, no other Honda motors will bolt up that includes wiring harness and transmissions and shift linkage.
A swap is complete swap, nothing from the bastard b connects or works with any other Honda platform.
We are the bastards of Honda.
If you want to swap you need my swap kits and harness conversion and traction bars.
