Group Buy open for this swap kit - 1FunRyd & MustardCat - 88-91 Prelude B16/18/20b/z Swap kit group buy
1. Update: First start up video -
2. 02/10/2017 Update: Motor up and running smoothly - https://youtu.be/WcZDCoa3jz8
3. Update - 02/12/2017: Quick test launch, no catback stock JDM motor - https://sendvid.com/kos4866f
So due to some issues beyond my control, I had to move on and spend even more money to finish the B-Series kit.
I have found someone who cares about this community as much as I do for aftermarket and performance for our beloved chassis.
I decided to make a new thread since I was moving away from the old vendor due to his personal issues that has cause me massive problems.
So here is what I have been doing in the background with my new partner in crime.
This thread will document my personal build to get the project lude up and running and show the fruits of my work to finish what I start.
And also because we all love a good build.
Project B20b swap
5-20-2016:
The B20b - I and my parnter(to be named later) chose to go with this motor for this build because we wanted to keep our discplacement and torque.
We all know that the B16, B18 motors are pretty torqueless platforms to begin with and as a community we prefer not to lose what we are already used too.
Not to mention that this motor from http://www.jdmenginedepot.com/jdm_e...bd2-high-compression-low-intake-jdm-b20b-b20z -
was priced just right for an affordable OE replacement for aftermarket support and OE support as well.
$586 shipped from New Jersey to WA state.
Delivery Day - 5-20-2016
We picked up and S80 transmission which is the none vtec integra B-Series transmission.
Side by side comparison between its older bastard brother...
As you can see the swap is going to get fairly good ground clearance for those who want to stay the low life while being in the same neighborhood as its older brother.
The motor was dropped in with no mounts on just sitting in the bay to get a sense of what we are looking at.
Not bad...
Since I already figured out most of the dimensions from the first B16/18/20 swap kit we have a good idea of what to do.
We however are going to try to reduce the amount cost for us and you guys as well to get the most affordable and efficient kit on the market.
After doing much research on the swap, and since the K series is the most dominant conversation for all the civic/integra/newer prelude guys, this leaves us to be able to affordge and enjoy a plethora of aftermarket support for this swap.
We will be getting the B20b running first then after we get it all running right, then we will be doing the B20vtec conversion.
To be continued....
Project B20b swap
5-20-2016:
Not bad...
To be continued....
